Scary auction -
Mike Schotte
04-19-2004 10:55:58
From the auction description (and I'm not making this up): "Previous owner used kerosene as coolant."
Yikes!- I'd hate to boil over the radiator on THIS tractor!
-Schotte
Gene Dotson
04-19-2004 17:14:34
 Re: Scary auction - in reply to Mike Schotte, 04-19-2004 10:55:58
Mike; The rumley Oil Pull uses kerosene for coolant. My brother used hydraulic oil for coolant in his Minneapolis UB pulling tractor. Sure wouldn't have to worry about mineral buildup in the cooling system... Gene
RoyG
04-19-2004 16:20:10
Back in the early 50's I ran kerosine in my old Pontiac as the cost of kero was 5cents a gallon and antifreeze was over 15cents. After kero is heated and cooled acouple of times it will not burn.
CASEPOWER
04-19-2004 15:19:59
Mike, Way back when they used a lot of stuff to keep them from freezing. Some mixtures also had higher boiling points like "honey" mix it with water and your boiling point is raised to 225 degrees and good for 0 degrees . You can also use Denatured alcohol, wood alcohol, glycerine or calcium cloride. One gallon of water to 4.5 quarts of denatured alcohol is good for -20 degrees, but will boil at 187 degrees. Kerosene or any other light oil are a great antifreeze solution, but does not mix with water good and must be used alone and is a fire hazzard.
Mike Schotte
04-19-2004 16:51:16
 Re: Re: Scary auction - in reply to CASEPOWER, 04-19-2004 15:19:59
CASEPOWER and RoyG-
Thanks for the info. I'd definitely never heard of that before.
I suppose the volatile stuff evaporates from the hot kerosene and leaves behind the heavier stuff?
I don't think it would ever occur to me in a million years to use a flammable liquid in a near-boiling application. (and it still doesn't!) *grin*
-Schotte
Don L.
04-19-2004 11:49:26
Interesting coolant. Say, there is another interesting Ebay item that has sold, item 2389286139, not tractor related . I got a bang out of reading it. Don L.
42FarmallH
04-20-2004 09:54:35
 Re: Re: Scary auction - in reply to Don L., 04-19-2004 11:49:26
That has got to be the best read I've ever had! I've had some Wally World and JC-junk tools that made me feel that way!
Mike Schotte
04-19-2004 16:51:55
You're right, Don- that auction is hysterical.
-S.
