VAC tranmission
tomturkey
04-19-2004 07:37:59
What years transmissions are interchangable with the 1950 model VAC?
CASEPOWER
04-19-2004 08:38:46
 Re: VAC tranmission in reply to tomturkey, 04-19-2004 07:37:59
All VA series. The VAS and VAH are the same also, just more parts changing to put one in.
tomturkey
04-19-2004 09:34:06
 Re: Re: VAC tranmission in reply to CASEPOWER, 04-19-2004 08:38:46
So Mr. Casepower man, any VA series year will interchange with the 1950 Model VAC? So the internal gears and shafts are the same. I have seen other years, they appear the same just wasn't sure about the guts. Thanks for your help.
CASEPOWER
04-19-2004 10:53:10
 Re: Re: Re: VAC tranmission in reply to tomturkey, 04-19-2004 09:34:06
As Augie stated, the bull pinions are different between the disc and drum brakes. The gears in the tranny and the case's are the same. There's a few VAI and late VAC-14 tractors that may be geared different, but first there hard to find, and second the parts will interchange in the case if your changing it all. If you list what parts you need I am sure Augie will be more then happy to tell you if you have the common parts, but if yours is a 1950 and the parts are original yours will be the common ones. Enjoy your tractor and stay safe!!
mj
04-19-2004 16:31:00
 Re: Re: Re: Re: VAC tranmission in reply to CASEPOWER, 04-19-2004 10:53:10
The gears are the same; their position in the case is what gives the different gearing between models.
Dan Kelley
04-19-2004 11:20:17
I read on this site, a week or two back, where the VAI shifted more like a car's 4-spd, and the VA, VAC shifted so the shifter handle would be out of the way during field work. Not sure if that's true, but it sounds good. I've got a VAIW, and it shifts like a car's 4-spd. Of course, I don't shift while in motion. I ain't that talented. :-)
Augie
04-19-2004 10:04:10
There are some differences between the disk brake and drum brake rear ends, but the tranny parts are the same. If you have any specific questions fire away - I've got the parts book...
tomturkey
04-19-2004 13:08:13
 Re: Re: Re: Re: VAC tranmission in reply to Augie, 04-19-2004 10:04:10
thanks for all the help, the saying is so true, no one of us is as smart as all of us. thanks so much
ted
04-20-2004 07:36:24
 Re: Re: Re: Re: Re: VAC tranmission in reply to tomturkey, 04-19-2004 13:08:13
I was told that the the SP-9&12 and also the 120 combines had a VAC transmission. If you have a old combine boneyard around you might find a trans with very little wear.
