dc case magneto
leigh maye
04-18-2004 21:27:33
have read the book on timing but still wont fire up what might have i did wrong? whom may i ask?
Robert Pence
04-19-2004 11:20:13
 Re: dc case magneto in reply to leigh maye, 04-18-2004 21:27:33
I'm not sure about the DC mag, but with some mags, if you install them tight against the drive coupling, the impulse won't trip properly. You need to leave a tiny bit of space.
Robert Pence
04-22-2004 19:05:56
 Re: Re: dc case magneto in reply to Robert Pence, 04-19-2004 11:20:13
It just dawned on me that I was completely out in left field on that answer; the DC has a flange-mounted mag, doesn't it? I was thinking of the L and C series, which use base-mounted mags. Sorry. Dumb.
leigh maye
04-19-2004 21:07:48
my brother and i have done everything the way the case manual said to do,the no. one is in front by rad. with pulg wire on no.1 cap d is in inspection hole, rotor is pointed at 1 on cap,put tight to block,turned over click was heard,d was in hole. moved mag to center. wont fire up?my brothers email is [email protected] we are pulling hair here.
ted
04-19-2004 04:48:10
1)Check and make sure the mag is hot. 2) make sure your grounding switch is not engaged. 3) Do you have compression? 4) Do you have fuel?
leigh maye
04-19-2004 09:07:10
 Re: Re: dc case magneto in reply to ted, 04-19-2004 04:48:10
its hot even traded with a runing tractor now both dont start.
Klyde
04-19-2004 09:42:04
 Re: Re: Re: dc case magneto in reply to leigh maye, 04-19-2004 09:07:10
Gotta time it! 4 different ways it will go.
ted
04-20-2004 05:18:23
 Re: Re: Re: Re: dc case magneto in reply to Klyde, 04-19-2004 09:42:04
Ok, check to see if you have spark, with mag on the tractor, by pulling off a wire and holding it about 1/4 inch from the block. If your eyeballs light up you may have a bad wire. Make sure you have fuel in the carburator. Now, here is the tried and true way. Pull out the number one plug. Put your thumb over the plug hole and crank the engine. When you feel pressure stick a piece of wire down the plug hole and bring the piston to the top. Set the mag so that it is just fireing at that point and hook that post to the #1 cylinder,(it dosn't matter which one it is) then follow the rotation of the mag with #4,#3,#2. Have the mag set in the middle of the advance arch and try to start. If it backfires retard it a little and try again.
