adjustable front end
tired
04-18-2004 19:55:35
I'm trying to get the left axle extension out of the center axle. The right side came out okay. It's got some surface rust, but ity should be no problem to clean up and anti-seize. However, the left side is a diffent story. I sprayed penetrating oil in there (both from inside the center axle, and on the outside), tapped on it with a sledge hammer, tried prying the center axle split-lines apart a little, even tried (gently) pulling the extension out with the SC.
It won't budge. The clamp came off without too much difficulty, so I don't think anything is messed up in there, at least that would be keeping it from moving. Any ideas? Would heat help?
