Case 1970 M570AT
Paul Spencer
04-18-2004 08:58:52
I bought and old Case from a military base that had been used to move aircraft around a runway here in Maine. It was later converted to have a backhoe and bucket. For the last two years it has run perfect in every way. This spring I went out and it started right up all the hydrolics worked perfect but it seems like the clutch has left the building???This has a 4spd trans and like a high and low range located to the left of the steering wheel. The clutch which seems to be hydrolic is only used to change gears, as it would seem there is a torque converter that does the work. There was never a sign of weekness no slippage smells or anything.but now when the clutch is depressed it seems to do nothing. I followed the linkege and it seems to be a shuttle type lever which still moves free and easy. Any ideas would be welcome as I can't even find amanual locally as Im told this was military and my local dealer would really like me to just trade.... Thanks Paul Spencer
The Wizzzzz
06-16-2005 13:56:53
 Re: Case 1970 M570AT in reply to Paul Spencer, 04-18-2004 08:58:52
I have one of these too, did you get to the root of the problem? Did you find a manual?
John Saeli
04-18-2004 10:13:43
Hey Paul: The tranny you describe sounds like the classic Case O Matic, but I wasn't aware they were used in the 570. I'm not suprised your dealer would like to trade as any number of guys would like to get their hands on that 570. That lever on the left you refer to as a hi-lo is actually a direct drive lever. It locks the Torque Converter up into Direct when you pull it down. Does it return to the up position when you push on the clutch pedal? If I understand your problem, the tractor keeps moving when you depress the clutch?
Paul Spencer
04-18-2004 11:46:18
 Re: Re: Case 1970 M570AT in reply to John Saeli, 04-18-2004 10:13:43
John; Yes when you depress the clutch that does work as it always did. The problem is after start-up when you depress the clutch to place in gear it will grind as if the clutch had stopped working. I think this might be no more then a fluid problem but can't seem to locate a way to check. Like I had said everthing was working perfect with no sign of any problem till it just stopped working. This tractor is old(1970) but has very few hours on it...
John Saeli
04-18-2004 16:06:00
 Re: Re: Re: Case 1970 M570AT in reply to Paul Spencer, 04-18-2004 11:46:18
Hey Paul: When the discs get warped, the output drum of the converter will drag like you describe. If you start it in gear will it creep? I just rebuilt the converter in my 800. I always started that in gear so I wouldn't have to "grind" it in.
