Case L Value
Scott
04-17-2004 06:18:03
I have never owned a Case Tractor before. I was shown a very straight, original 1937 Case L. The tractor supposably runs nice. The only problem is the radiator leaks. This tractor looks like it had been put away every night from the field. What would a value be for this tractor?
Dave - Illinois
04-17-2004 17:15:50
 Re: Case L Value in reply to Scott , 04-17-2004 06:18:03
third party image
Hello Scott,
I paid $1900 for this '38 a little over a year ago. Loose but not running. Has electric start, generator and lights.
I'm going to try and get it running soon. All I need to find is some extra $ :-)
Dave Olson - East Central Illinois
Brian in Ohio
04-17-2004 08:42:11
If the tractor DOES run, and doesn't require any work to the engine, except the radiator core, all the sheet metal is straight, and just requires clean up and paint, I'd go around $1000. I put a new radiator core in my 34 "L" two years ago for right around $300, and that was just for the core. I cut the gaskets and put it together myself.
Bob
04-17-2004 16:19:53
 Re: Re: Case L Value in reply to Brian in Ohio, 04-17-2004 08:42:11
I paid Aus $1800 (about US$1200) for a good straight original 1938 L on steel wheels about a year ago. It is a different market, but I thought it was reasonable buying.
A 1937 model L should by LC grey, not flambeau red. Apparently, some of the very last Ls were flambeau red.
Scott
04-17-2004 09:40:25
Where did you find the radiator core?
Is there anything I should pay particular attention to? I assume the exhaust goes straight out the side. Is the correct color gray? I have seen some painted orange.
Robert Pence
04-19-2004 11:33:38
 Re: Re: Re: Case L Value in reply to Scott , 04-17-2004 09:40:25
I bought a five-row core for my 1937 L from Ace Auto Radiator Co., 9304 E 40 Hwy, Independence, Mo. for about 315 dollars. Freight was free, quality and fit were perfect, and it arrived less than a week after I ordered it. Also at AceRadiator.com.
That was about six years ago.
Brian in Ohio
04-17-2004 18:35:15
I had a local radiator shop order a new core for me. He said that he ordered it out of a company from Michigan, but he didn't specify what company. If yours needs replaced, I'd either take the whole radiator to a local repar place and have them replace it, or take it apart yourself, and have them get you a new core, and let them get measurements off of the new one.
Les...fortunate
04-17-2004 11:18:00
Go to the tractor photos on this site and search for Case L. There should be plenty of pictures of them for you to look at.
