spark plug gap,1952 vac
Richard Shackel
04-15-2004 17:00:55
Does anyone out there know what the gap is on a spark plug and the points for a 1952 vac....Thanx...Richard
John L.
04-15-2004 17:09:52
 Re: spark plug gap,1952 vac in reply to Richard Shackelford, 04-15-2004 17:00:55
Points should be .020 and plugs should be .025 to be "by the book". However depending on the plugs you use, you may need to adjust that plug gap a bit. I've been told that today's plugs are somewhat hotter and therefore require a small adjustment to the gap for optimal performance.
Les...Hmmm
04-15-2004 19:31:30
 Re: Re: spark plug gap,1952 vac in reply to John L., 04-15-2004 17:09:52
My manual says .028. I put mine at .030 and drag it through. My plugs foul anyway although not as bad since I put in the anti-fouling device on #1 and #4.
Richard Shackelford
04-15-2004 18:30:22
John,
The points in it are new,I set them to 020 and the vac acted as if was not running as good.so i put it back to about 018 and it ran good.The plugs are champion D-21.I do not understand the hotter plug adjustment,do you mean to make the gap bigger or smaller??? I pulled the plugs and the end of them looked like they had soot on them.Maybe the carburetor needs rebuilding..Thanx..Richard..My e-mail is [email protected]
Joe (Wa)
04-16-2004 01:37:52
 Re: Re: Re: spark plug gap,1952 vac in reply to Richard Shackelford, 04-15-2004 18:30:22
Factory Vac plug was Champion D-16 (now cat# 516) gapped @ 0.025". The D-21 plug is a couple heat ranges hotter plug. I don't believe the newer plugs are hotter in a given range I.E. the D-16 number designates the configuration, material, and heat range of the plug. If you want a hotter plug of this configuration and material, you would go up in heat range to D-19 or D-21 or an auxiliary gap plug of that configuration.
The heat range of any plug can be elevated some by increasing the gap slightly. All you are doing here is retarding the discharge of the coil and firing the plug at a higher voltage. This can also be accomplished by a gap in the wiring connection or the plug core electrode (auxiliary gap).
The color of the deposits on the plug doesn�t mean much unless the engine is run at design rpm and load since firing pressure is required to keep the rings fully seated against the cylinder wall. Your are not going to do that idling, light loaded, etc. The normal color of a properly firing plug and fully seated rings is white-gray. In reality unless you just finished plowing for several hours the color will be black with varying, if any, gray.
The points should be set @ 0.020". If you set them @ 0.018" the timing will be very slightly later than set @ 0.020" because the actuator will have to be higher on the cam before the points open. Engines run faster, up to a point, when the timing is advanced so if yours runs "better" (assuming you mean faster) when you decrease the point gap is your initial distributor timing correct?
Joe
John L.
04-15-2004 20:19:24
Well, if I recall correctly that soot probably means too rich a mix from the carb. It's been a while since I've really been able to play with any of these machines for any amount of time, so my memory is getting a bit foggy about plug deposits.
I *believe* what the person who explained that to me meant was that newer plugs tend to run hotter - that is the physical plug temerature increases to higher temperatures than older plugs - and therefore are less suseptable to fouling. I believe the gap adjustment they meant would be to increase the gap slightly to accomodate better efficiency in today's plugs compared to those of 50 or so years ago.
How true is it? Well, I was hoping someone else here had heard the same story and would chime in with how to - and why to - adjust the gap for newer, potentially hotter plugs.
I'd love to hear from someone who has done some testing - even some subjective feedback - on how adjusting plug gap beyond the specs from our 50+ year old manuals works out.
As for the gap plug, hey if .018 works, go for it.
Richard Shackelford
04-16-2004 19:09:34
 Re: Re: Re: Re: spark plug gap,1952 vac in reply to John L., 04-15-2004 20:19:24
Now that i am totally confused as to what the gap should be,i suppose i will set it to 030 for plug and 020 for points and see how she runs.The vac runs pretty good it is just the plugs get all sooty and she just runs as thou she is missing a little bit.maybe i will have the carb rebuilt....Thanx for the help out there...Richard
Augie
04-16-2004 12:27:48
I'm running D16's gapped at .035" with a Pertronix Ignitor and 40KV Fireball coil in my VAC. Works great...
