Outer belt pulley seal number needed ??
Alberta Mike
04-14-2004 14:09:35
I am in need of the outer seal from the belt pulley assembly on a Cas model V. I think it would probably be the same as the seal from a model VA since the pulley assemblies were the same (I think). Anyways, the Case number stamped on the seal is VT2316, no other markings are on the seal and I know that all Case seals were marked with the VT prefix. Anyone out there know what a cross-over equivalent would be from one of today's seal manufacturers? I can always go from measurements but I prefer the ID method.
Bob
04-14-2004 16:03:13
 Re: Outer belt pulley seal number needed ?? in reply to Alberta Mike, 04-14-2004 14:09:35
National 450803.
Alberta Mike
04-14-2004 20:32:09
 Re: Re: Outer belt pulley seal number needed ?? in reply to Bob, 04-14-2004 16:03:13
Thanks Bob, that is quite a reference page on the link you gave, I wish the local bearing houses would've had something like that last summer when I did the brakes and needed to replace the seals in the rear axle housings .... that was a job to get the right ones, they worked but I did it from measurements and I was always wondering if they were the right size exactly.
