case sc vs. case 311
jpbm1976
04-14-2004 07:00:02
Hi all , I own a 1949 case sc. I JUST got done reworking it . I have a chanse to buy a case 311.
I dont know much about the 311, so I thought
I would ask all of you.The price for the case 311 is durt cheap and it runs.But you know how that gose. you never know what you get.With that said,
how do the two stack up? would this be a wise trade off? Any info would help. plus anyone want a good SC drop me a line. Thanks, jpbm
John H
04-14-2004 18:29:55
 Re: case sc vs. case 311 in reply to jpbm1976, 04-14-2004 07:00:02
Is the 311 the round nose version? If it has the triple range and narrow front its a darn good tractor. Having spent hours and I mean hours the 300 is much more tractor than the SC. Not puting the SC down but your are talking 3 bottoms versus 2 plus live power. We always had fluid in all our tractors plus a front weight on the 300. Never had problems with the front end coming up but man, if you want one that comes up easy take the weight out of the front of the SC. Uncle bought one new that they left the weight out and it came up too easy. Made them put it in in a hurry.
jpbm1976
04-15-2004 05:40:46
 Re: Re: case sc vs. case 311 in reply to John H, 04-14-2004 18:29:55
HI again, I found the model number on the case 300, its a 311b 1957. Not sure if that is good or bad. The main reason I want this tractor is for the three point hitch. There is a piece/broke off on the 3 point. Its the bracket that holds the right side lift arm to the tractor. I hope the parts are easyier to find for the 311b than the SC.Any one know the horse power of each tractor? I run about 7 acres of pumpkins. Its all nice and flat ground.
I would love to keep them both , but just dont have the room. Any help on a good source for parts for the 311b would be great.Thanks for all your help . jpbm1976
C. Amick
04-14-2004 13:37:28
I have both a 311 and several SC's. I put a 3-point hitch on one of the SC's that has the lifting bail on it. I added a second hydraulic cylinder on the right side. The SC will lift more that the factory Eagle Hitch on the 311 due mostly to the fact that the SC is heavier and the front won't come off the ground as easy. The 311 is much easier to start in the Winter. My 311 has a tricycle front and is very easy to steer. The 311 has more horsepower than the SC, but mine needs more weight added to take advantage of it. Which tractor is better, depends upon what implements you want to use.
Will
04-14-2004 09:35:37
Get the 311 and keep both. You won't be sorry.
Coloken
04-14-2004 08:11:40
Apples and oranges... 311 has foot clutch live pto (that by way of tran clutch) 4 speeds amd maybe up to 12 if extra trany And last but not least a 3 point When I got my 300 I wondered about how much the 3 point would lift, it yanks a 6 foot bush hog up so fast it rattles my teeth. I assume you mean the 300 round nose and not the later 300B. Only thing I have against mine is no power stering. Oh, watch out for a cracked exhaust manifold. they come high. The SC is probably one of the best tractor ever made, but..... .
