VA vs.VAC
Bruce from Boul
04-12-2004 13:03:12
What is the difference? Is the VAC just the tricycle version of the VA? Is the torque tube case interchangable? I just got a 1947? VAC with a hydralic lift. The area around the bolt hole where the lift rocker attaches to the torque tube case is cracked. I know where there is a pile of VA parts five hours from here. But I'd like to know if the parts are interchangeable before I make the trip.
mj
04-13-2004 08:28:44
 Re: VA vs.VAC in reply to Bruce from Boulder, 04-12-2004 13:03:12
The VA SERIES included the 'VA' which was very similar to the VAI and VAO configurations (see chart on the link below) with the main differences being lighting and muffler layout. A VAC can be a single, narrow or wide front, both adjustable and non-adj. The torque tubes for the high pressure system (yours) are the same throughout the line. The torque tubes for later tractors fitted with the low-pressure system and live, engine-mounted pump interchange also, but you would need to add the live pump, lines, and a 3-point hitch with control valve (the late Eagle hitch has the control valve attached). With a bit of 'Baja-engineering' you can add the functionality of the live pump at a later date, however, wthout changing torque tubes. The mid-mount implement yoke will not fit the late torque-tube but if you go that route you will probably be up-grading to a 3-point as outlined above anyway. Find your torque-tube casting number and compare with the one you are looking to buy to be absolutely certain of interchangeability.
Bruce from Boulder
04-13-2004 15:58:16
 Re: Re: VA vs.VAC in reply to mj, 04-13-2004 08:28:44
Thanks MJ, that was exactly what I needed. It also cleared up some other questions. This is my first Case (I have an AC WC and Oliver 70). This VAC has had some after market work - it has the high pressure pump and a low pressure pump mounted to the end of the shaft. The high pressure pump is disabled. It has a three point hitch (but not an eagle hitch) and it is operated by the original mid-mount implement yoke. And now I know that the home made looking piece of wood over the spark plugs is supposed to be there (although I can't imagine why). Thanks again for the help from you Case guys. It sure helps to talk to the experts.
Bruce from Boulder
04-14-2004 11:19:19
 Re: Re: Re: VA vs.VAC in reply to Bruce from Boulder, 04-13-2004 15:58:16
Thanks MJ, now the wood makes sense.
mj
04-13-2004 23:55:51
third party image
Bruce- Go to the link that shows this photo (number 40) and click on it to read comments explaining the purpose of the wooden bar.
Joe (Wa)
04-14-2004 10:53:17
 Re: Re: Re: Re: VA vs.VAC in reply to mj, 04-13-2004 23:55:51
Wow mj, does that lp pump still have the spur gears in there? Joe
martin in DE.
04-13-2004 13:38:48
mj, tell me more about a VAC with the non- adjustable wide front. martin
mj
04-13-2004 23:44:12
 Re: Re: Re: VA vs.VAC in reply to martin in DE., 04-13-2004 13:38:48
third party image
Martin- I've only seen one and I'm thinking that it started life as a single or narrow front and someone changed it over to a non-adj. wf BUT right after WW2 Case was sticking tractors together any which way they could because of the demand. This could have been done by an owner or a delaer with ease. The only sticking point is that the steering pitman arm moves opposite to a sf, nf or adj. wf due to the linkage arrangement on the n. adj. However, it's a simple matter to reverse the direction if you are 'in the know' which most of the dealers probably were. It's a matter of removing the steering gear and turning over the worm and worm gear; then they operate in reverse. Did Case send them from the factory as VACs with the non-adj. wf? I don't know....maybe somebody will tell us. I've got a complete na, bolster and all and may convert my sf to it. But I've got a VAO which uses the same front end so maybe not! You can see some of these variants on the link below. Click an image to enlarge.
