Case J44 mower deck
David J. Beiter
04-12-2004 08:58:40
Here is one for all you Case gurus!! I have a Case 222 riding mower with a J 44 44" deck, problem, In moderate to heavy grass it misses a 2" swath between the center blade and outboard blades. I have replaced the blades, deck belt, drive belt and several bearings to no avail!!! help
thanks
Max
04-13-2004 16:25:00
 Re: Case J44 mower deck in reply to David J. Beiter, 04-12-2004 08:58:40
The blades are to far up into the deck for heavy wet grass. This was always a problem with the Case decks whether its a J44, J46, or what ever. The best way to fix is to trim the leading edge of the deck so that it is about 1/8" higher than the cutting edge of the blade. If you trim it any higher the only thing that will be accomplished is the throwing of projectiles out the front of the deck causing flat tires on the front wheels and possible personal injury to someone. The best fix is to mow more often.
Klyde
04-12-2004 19:09:57
No they don't have to be "timed", but it sounds like you have the wrong blades. The next smaller mower is a 38". the only other thing I can think of is a frozen idler bracket on the deck belt not keeping it tight enuf. I'll check the spec on the blades tuesday, an let you know.
Glenn/Mn
04-12-2004 09:59:06
I am asumming the blades you have are identical length, you need to time the two blades opposite the discharge, I other words they need to be in sinc 360 degrees or come together at one point in a circle excatly at the same time, I hope you can understand that
