Tourq specs for head replacement
jody eley
07-14-1999 17:07:03
im looking for the tourq pounds for a 1951 case 400, gas 251 split head im replacing the head gasket and need the right order to tourq and the foot pounds please e-mail me if you have any information that would help me thank you
Ron
07-14-1999 18:41:05
 Re: tourq specs for head replacement in reply to jody eley, 07-14-1999 17:07:03
Jody---- Are you sure your 400 is a 51 model? I don't think the 400 was built until around 55 or 56. Anyway I have one which I recently replaced the head gaskets. You torque them down to 100 lbs. Also there is a special sequence to tourqing the bolts if you do it right. Hope this helps.
Jerrie Lott
07-14-1999 21:12:17
 Re: Re: tourq specs for head replacement in reply to Ron, 07-14-1999 18:41:05
Jody I have to agree with Ron, your 400 is a lot newer than 51. We have a DC that my Dad bought new in 1956, and I'm sure that it is 1955 model, which I think is the last year for DC's. They could have also made 400's the same year but would not have made them before the same year that they discontinued the other model. It is hard to remember when all of these models changed because they change them in different years. The VAC they made until 1956 before they switched to the 200 but I think they quit making LA's in 1951 or 52 and switched to 500. There is a formula for subtracting something from the serial number to find out what year it was manufactured, but I can never remember it, maybe someone will see this and remind us of how to find the manufacture date from the serial number. Hope this helps. If you can't find the tightening sequence, it will work alright if you remember to always start in the middle and work out ina type of rotationback and forth across the head ending up on one end or the other. But I can't tell you what the torque values are for that tractor, sorry. Jerrie
pat favors
03-23-2002 16:45:01
 Re: Re: Re: tourq specs for head replacement in reply to Jerrie Lott, 07-14-1999 21:12:17
i have a 283 and 441 heads also i have a z28 intake and i need a cam that will create enough vaccume for a daily driver can you help me please?
Ron
07-14-1999 18:41:03
