830 pistons in a 730
Keith
04-11-2004 17:38:01
I have a 730 comfort king in need of an overhaul I was wondering if I could put 830 pistons and sleves in it using the same heads, crank and rods. Would this work? Would there be much increase in power if any without major modifications?
DKase
04-11-2004 19:56:43
 Re: 830 pistons in a 730 in reply to Keith, 04-11-2004 17:38:01
You would have to bore the block to accept the larger diameter sleeves. Stroke is the same on all the racine built diesels. Bearings fit everything from the 500 through the 2290, that includes the 4 cyl. tractors. Thrust bearings might be different thickness though.
