410b tension headache
Shaker
04-11-2004 09:18:56
Restoring 1959 410b.Hand throttle and hand direct drive lever have different size coil springs on lower shaft.Does anyone know what one is supposed to have the more tension? Thanks Dave S
JohnM
04-11-2004 09:42:00
 Re: 410b tension headache in reply to Shaker, 04-11-2004 09:18:56
Where on the lower shaft? Just as a guess, I would say the throttle wants more tension. That one is supposed to stay put, while the COM is supposed to kick out when you step on the "clutch". If you want I will try to get numbers from the parts book.
Shaker
04-11-2004 17:36:14
 Re: Re: 410b tension headache in reply to JohnM, 04-11-2004 09:42:00
John springs are about three or four inches under friction disks.I have part numbers but cant tell by that. Thanks,Dave
