fuel in coolant- John S
John Suchocki
04-11-2004 06:37:11
Hope some one can help. I have a 580 ck backhoe that I rebuilt last year. I only replaced the oil seals in the 188 engine and have just found diesel oil in the antifreeze. Never had that as a problem before. The engine runs fine it seems for a 5,000 hour motor. I just don't like the fact something is wrong. Any sugggestions would be appreciated
Rollin
04-11-2004 10:17:42
 Re: fuel in coolant- John S in reply to John Suchocki, 04-11-2004 06:37:11
Do you see bubbles in the coolant or it pushes coolant out of the overflow when it's running ? If so it's a leaking head gasket or cracked head. I went through this last year with a 730 Diesel.
John Saeli
04-11-2004 10:15:39
Hey John: By diesel oil I assume you mean engine oil? If so, does the 580 have an oil cooler?
John Suchocki
04-11-2004 11:03:04
 Re: Re: fuel in coolant- John S in reply to John Saeli, 04-11-2004 10:15:39
no, its fuel oil that seems to be rising to the top of the radiator.Not in hugh amounts but enough to be a problem. john
