Thoughts on 1570
Wayne
04-10-2004 16:20:58
Took the Big Dog to the field and noticed left brake was softer than usual. Right brake seemed normal.Power shift works fine.Hydraulics work fine.Now I need to spin steering wheel several times before the front wheels turn.Have I got a big or small problem?
brent
04-10-2004 20:26:07
 Re: Thoughts on 1570 in reply to Wayne, 04-10-2004 16:20:58
According to the manual, those two items are run by the same 8 gpm pump. The fluid goes to the brake valve before it enters the steering valve. The fluid goes through the steering valve, then to the oil cooler, and to the reservior.
Another thing to check - does diff lock affect the steering?
There's a check procedure to figure out what's going on. It uses a flowmeter, pressure guage, and some valves to place a load on the pump.
The pump should be accessible from the outside - it's mounted on the right hand side of the tractor, if I remember right. I can send you the pages in the manual if you want.
Wayne
04-12-2004 14:20:34
 Re: Re: Thoughts on 1570 in reply to brent, 04-10-2004 20:26:07
Brent, thanks for responding to my question.I also have the service manual.What I could'nt understand was why Right brake was not affected. Anyway,I bled the left brake and that seems OK.I also found one of the steering cylinders had broken the ball joint just below the castle Nut.Will replace that in the morning. Thanks again!
