Case 311 Any good ??
Sam F.
04-09-2004 21:11:18
Have an opportunity to buy a Case 311 from an old timer. He says it runs and works good. Wants $500 for it. Are these a good tractor for around the farm ?? Rough weight ?? Give me the good and bad. Thanks fellas.
C. Amick
04-12-2004 13:55:47
 Re: Case 311 Any good ?? in reply to Sam F., 04-09-2004 21:11:18
I gave $1,600 for mine and it needed some work. It is a little light on the rear without wheel weights or fluid. Brakes are not the best design, are easy to repair. They will continue to give you problems if you leave it out in the weather.
case poor in pa
04-11-2004 18:45:38
iffen you dont want it. ill take it.. what a deal
BLR
04-10-2004 22:26:16
They are a fine tractor. If it runs, and everything works $500 is a steal, period.
JRT
04-09-2004 22:18:12
In my opinion, one of the best little Case tractors ever made. especially if they had the extra hand clutch and triple range transmission. The brakes are not the best ever made, but they are fairly easy to work on. They had excellent hydraulics and with the 12 speed transmission, you have a gear for about anything you want to do, including traveling at 25 miles per hour on a smooth road.
Russ
04-11-2004 08:42:10
 Re: Re: Case 311 Any good ?? in reply to JRT, 04-09-2004 22:18:12
311;1959Case 310B, 4 cyl,148 CID gas,xmsn 12F-3R,
3235 lbs, lo 1550, mid 2220, hi 2780. These figures are from an available guide. I would give the man his price, thank him and start enjoying the rebuild.
ted
04-09-2004 22:49:27
One of the good things about that 300 is that it has the same block as the 400b,500b,600b. Is that right? Anyway, I had a 400B, I was told it had the same engine as the 300, and it had been suped up to almost 50 hp by changing pistons and sleeves.
martin in DE.
04-13-2004 13:55:39
 Re: Re: Re: Case 311 Any good ?? in reply to ted, 04-09-2004 22:49:27
Ted,the block is not the same as a 400B,500B or 600B. it is a 148 cid small crank engine, all internal parts are the same as a 400B,but the block is different. The 500B and 600B tractors had the 164 cid dry sleeve engine.
farmall
04-12-2004 14:49:53
Ted, The 300B & 400B had a 148 cid engine. The 500B & 600B had a 164 cid engine
