Need 336 turbo engine for 1973 Case 780 CK
Kevin
04-09-2004 07:23:37
My mechanic was checking out an old (1973) Case 780 CK loader/backhoe that I was about to buy at a good price when the 336 turbo engine clanked and froze. I'd like to find a way to make the deal still work so I can get the machine and the seller isn't stuck with junk. I'd appreciate any suggestions on a minimum cost way to get a replacement engine. Does anyone know if any ag equipment used the 336 turbo?
John Saeli
04-09-2004 18:06:45
 Re: Need 336 turbo engine for 1973 Case 780 CK in reply to Kevin, 04-09-2004 07:23:37
Hey Kevin: The 336 was used in AG & Industrial. It was used in the 870 Tractor. Very rugged and economical engine.
Butch/ OH
04-09-2004 18:04:13
Kevin, That 336 engine as it is in your 780 [336BDT] was only used in the 780 and 880. The 870 ag tractor uses a 336BD and it has the heavy crankshaft, rods and wrist pins, but not the correct pistons for turbocharging. Those engines are also hard to find. 850B, 850C dozers, W14 wheel loaders, 680E, 680G backhoes also used a 336 engine,but I think all those used a lighter crankshaft.
Kevin
04-10-2004 05:53:18
 Re: Re: Need 336 turbo engine for 1973 Case 780 CK in reply to Butch/ OH, 04-09-2004 18:04:13
Thanks for your detailed information. I contacted one major salvage yard that offered me a non-turbo (336BD?) for $3750. They said I could put my turbo on it. What is different about the pistons that determines whether or not it will accept a turbo?
The same salvage yard told me the most common failure is the balance or thrusters on the crankshaft. I haven't torn apart an engine since high school shop class. Is there any point in trying to open up the frozen one in hopes of repairing it? There is a welded plate that is under the front of the block making it look impossible to pull the pan off. I'm guessing the whole block would have to be pulled out to do anything.
Lorraine
01-30-2006 14:47:35
 Re: Re: Re: Need 336 turbo engine for 1973 Case 78 in reply to Kevin, 04-10-2004 05:53:18
I saw your email regarding your Case engine 336BD. I am looking for an engine and wondered what salvage yard you found yours at?
Thanks, Lorraine
[email protected]
D Illum
02-09-2006 12:29:43
 Re: Re: Re: Need 336 turbo engine for 1973 Case 78 in reply to Lorraine, 01-30-2006 14:47:35
I have spent the lasr two years rebuilding a 336BDT for my 870 ag tractor I found the block in a salavage yard in Texas and had a local machine shop put the bearings and pistons in it. I use the old oil pump and low and behold after about 30 hours I lost the oil presure and locked the engine up. I used the pistons and crank out of mu 336BD and its now running fine so from my adventure I would say that you can turbo a 336BD with out any problems just make sure that you have good oil presure
