DE Power Unit All Fuel Manifold
L.Lamp
04-08-2004 22:27:41
The manifold is ok except for the control rod and rod it attaches to. Both are missing and there is about a 1" hole in the manifold where the rod should come out. It has small hoses attached where the 1/8" pipe plugs should be at the two intake ports, a 1/8" pipe nipple tapped into the carburetor just past the flange that bolts the carb to the air cleaner box. There was also a 3/8" pipe thread hole taped into the carb just before it goes to the choke valve. I don't know what all this hardware did but I am gessing they had some kind of crude propane system on it. The guy I bought it from thought it was for water injection. Maybe you know what they were doing. I am ok on parts. I have a 1950 block with a worn crank that I will swap out with the good one from the power unit. I am putting two of the power unit 3 7/8" sleeves in the '50 block and two other good sleeves I took out of my restored '51 DC along with their two cast iron pistons. The power unit pistons have a different number on them than the '51 pistons. I am going to take both pair to town and see if the weight matches and if they aren't to far off have the heavy ones machined till they match the others in weight. That will make sure the engine will remain balanced and run properly without vibrating. I have no idea what the manifold is worth so make me an offer. I have the special head intake port tubes also. My e-mail address is: [email protected]
