Will it fit?
Coloken
04-08-2004 20:44:19
Dumb question. Will a wide front from a DC fit on a SC? My friends SC with single front is 50 miles north and a junker DC with WF is 50 miles south. How about the whole DC block fitting into a standard S? The S needs a weld job from frezing.
DKase
04-09-2004 07:04:21
 Re: Will it fit? in reply to Coloken, 04-08-2004 20:44:19
If you are refering to the adjustable wide front, some of the parts are the same. I put a DC adj. wide front on an SC. I had to take the large cast piece from a narrow front SC that the radiator mounts on, and cut the bottom off, and have the center bored out to fit the wide front. It can be done but the set up in the mill is a &*%#@*&. I am sure Bruce could relate to that. LOL DK
Bruce Nelson
04-09-2004 05:24:50
None of that stuff will fit.
Jim
04-08-2004 20:59:41
Well, the engines don't swap, but I've never tried to swap front ends that that.
