SC Case Battery Cover
Glenn FitzGeral
04-08-2004 08:08:28
My late model SC needs a battery cover. Are they hard to find? Anyone have one for sale? Thanks, Glenn F.
dbb62
04-11-2004 19:56:07
 Re: SC Case Battery Cover in reply to Glenn FitzGerald, 04-08-2004 08:08:28
Don L is making reproduction SC battery trays and has them for sale. I don't have his contact info, but I know many people on here can get it to you.
Mike Schotte
04-08-2004 13:24:41
Are you talking about the hold down? There's no cover on the SC battery that I'm aware of... the gas tank support covers the battery.
-Schotte
Glenn F.
04-08-2004 13:52:54
 Re: Re: SC Case Battery Cover in reply to Mike Schotte, 04-08-2004 13:24:41
I didn't realize they didn't have a cover. Yes on the hold down bracket question as mine is currently held down with a bungie strap. Could you post a picture of one? Sounds like it's pretty simple. Thanks, Glenn
C. Amick
04-09-2004 12:24:09
 Re: Re: Re: SC Case Battery Cover in reply to Glenn F., 04-08-2004 13:52:54
I went to the hardware store and got some threaded rod, some wing nuts, and some narrow flat steel and made mine. I bent a hook on the threaded rod and put it through the bottom holes in the battery box on each side. I ran the flat metal piece across the battery and drilled a hole in both ends for the threaded rod to come up through it and put wing nuts on the upper end of the threaded rod to clamp it to the battery. If you try this, make sure you run the flat metal piece across on the ground post side the battery so that nothing shorts out.
Mike Schotte
04-08-2004 14:23:33
Never seen one except in parts books. Never met an SC that still had one.
Randy D made a homemade version and posted pics awhile back.
-Schotte
Glenn
04-08-2004 19:16:30
 Re: Re: Re: Re: SC Case Battery Cover in reply to Mike Schotte, 04-08-2004 14:23:33
What do the NICE show tractors you've seen have for a hold down? Glenn
Bob from WI
04-10-2004 17:41:39
 Re: Re: Re: Re: Re: SC Case Battery Cover in reply to Glenn, 04-08-2004 19:16:30
I have an 1945 sc and the battery hold down assembly is as follows.
There are two long carriage bolts that run up from the bottom through the plate on the tractor through a tray that the battery sits in. On the top of the battery is an "L" channel "frame" that fits the top of the battery. The "frame" is roughly 1" X 1". Welded to the short sides of the frame are small "sleeves" that the carriage bolts come up through with a wing nut on top to hold the whole kit and kaboodle together. Let me know if you want to see pictures, I can get them the next time I get up north. Mines not for sale (Ha,Ha.)
Glenn F.
04-10-2004 18:24:46
 Re: Re: Re: Re: Re: Re: SC Case Battery Cover in reply to Bob from WI, 04-10-2004 17:41:39
Thank you Bob and Mr. Amick for those descriotions. I'll be making one soon. Glenn F.
