David Brown hitch release
farmallmatt
04-08-2004 06:06:29
I have twisted off the hitch release handle on my DB 990. I can pull out the shaft enough to release the hitch. The problem is everytime I lift the three point arms the hitch release locks them in the upright position. How can I fix this?
Thanks
Matt
Mike Prince
04-14-2004 02:17:13
 Re: David Brown hitch release in reply to farmallmatt, 04-08-2004 06:06:29
My 990 selectormatic arms will not lower even with the hitch release pulled out! Any ideas.
Mike
Elmer
04-08-2004 09:10:52
Your quadrant lever is travelling too far. You will notice the lever butts up against a spring. The spring travel is adjustable. You will see the slotted hole. Adjust it ahead a wee bit. Do you want another lever?
farmallmatt
04-08-2004 14:30:41
 Re: Re: David Brown hitch release in reply to Elmer, 04-08-2004 09:10:52
Elmer,
My quadrant lever is okay. I am missing the springs. What is broken is the "hitch release" handle on the left lift arm. Do you have those or is there another way to fix it?
Thanks
Matt
Elmer
04-09-2004 07:34:10
 Re: Re: Re: David Brown hitch release in reply to farmallmatt, 04-08-2004 14:30:41
I will have a handle here. The transport lock will engage only due to maximum lift. That what the spring is in the quadrant for. Allows you to raise it just below the lock area.
