Case L Build Card?
Lawrence Woolf
04-08-2004 00:25:00
Are build cards available for Case L's? I have just bought one, tag no. 4405010. Its red, electrical start, but is it one of the last built, and who supplied it? Many thanks
dctom
04-08-2004 10:54:05
 Re: Case L Build Card? in reply to Lawrence Woolf, 04-08-2004 00:25:00
LAWERANCE, YOUR IN LUCK HAVE CARDS FOR L'S FROM ABOUT HALF OF 37 UP 4405010 WAS BUILT MAY 17 1940 AND SHIPPED TO J I CASE CO VERMILION, ALT, CAN. JUNE 12 1940, IT HAD 5" SPADE LUGS ON BACK AND SKID RING RUBBER TIRES ON FRONT, ELECTRIC STARTING AND LIGHTING ATTACHMENT, HIGH COMPRESSION PISTONS COMBINATION MANIFOLD IS IT STILL THAT WAY? DCTOM
Kenneth R. Allen
05-05-2004 19:47:30
 Re: Re: Case L Build Card? in reply to dctom, 04-08-2004 10:54:05
Recently puchased a Case Model "L" serial No. L440085. Runs... original paint of grey..red steel wheels front & back.... red radiator fan..original wooden platform... runs great..everything is original..has been in shed except for the past 18 months. When was it manufactured?.. I thought serial #'s starting with 44 had seven digits.. and manufactured in 1940. No electrical system... hand cranked... starts usually on third pull.
Thanks, Kenneth R. Allen
Lawrence Woolf
04-09-2004 00:42:22
Many thanks. It has rubbers front and rear, but has the original manifold. What serial number was the last Case L built? Should it be red?
Some of the lights are there.
dctom
04-09-2004 11:30:56
 Re: Re: Re: Case L Build Card? in reply to Lawrence Woolf, 04-09-2004 00:42:22
NEVER DUG ENOUGH TO FIND LAST L BUILT, I DONT KNOW IF IT WAS FLAMBEAU OR NOT, PERSONALLY I DONT THINK SO FROM THE FACTORY BUT MAYBE DEALER PAINTED IT TO LOOK LIKE LA DCTOM
