Head Milling Question for VAC
Smitty
04-07-2004 09:53:44
I am looking for more HP! Due to the large deep cavity in the VAC head I question if milling the head .050" is even wotrh the effort. Can anyone tell me if anything is to be gained by milling? Are there any other areas in the head that can be worked over to increase HP?
mj
04-07-2004 17:06:38
 Re: Head Milling Question for VAC in reply to Smitty, 04-07-2004 09:53:44
You will increase the compression ratio by milling the head and thus get more power. You need to think about the valve to piston clearance before you mill too much. Place modeling clay on the valve heads and turn the engine over with head gasket in place and head torqued to specs. and then remove the head and see how much the clay has been flattened, this dimension is what you have to work with. Always shim up the rocker arm shaft stands by the same amount that you have removed from the head to retain rocker arm geometry. A 'high altitude' piston and liner set will give you more power as will matching the ports on the head and manifolds. Another easy increase can be obtained by going to a 180 or 190� thermostat, following Smokey Yunicks' advice on that one when he said "Hot water and cold air make horsepower!". As an aside; the reason CASE installed 160 to 170� thermostats is that many buyers were still using alcohol-based anti-freeze which will boil out of solution and leave the water at temps much more than 180�. Before you mill you should cc the head combustion chamber and calculate the compression ratios for various amounts of milling. If your tractor is pretty long in the tooth a simple valve job and re-ring will surprize you. What are the compression readings on your engine? How long since the ignition system was renewed? Is the governor set to give maximum reccommended RPM? The VA engines in ag tractors are to be set at 1600 RPM under no load which gives the proper 540 RPM for power take-off operations BUT the same engine in the VAI is to be set at 1900 RPM and a stop was provided for a quick change to 1600 RPM if the power take-off was fitted and in use. The VA engines will live at 1900 and that alone gives them more guts. All of my VAs are set at 1900 and are fitted with 180� thermostats..... Roger?
mike
04-07-2004 18:13:30
 Re: Re: Head Milling Question for VAC in reply to mj, 04-07-2004 17:06:38
I milled my Vai head 125 thous. new valves seats, and guides. I used a copper gasket(25 thou) for a head gasket.I beefed up the spring presure rates.
Cranking presure was 195 to 200 psi.I turned it 2300 rpm . pull 2500 lbs class 5.0 mph in lst gear.
Smitty
04-08-2004 07:54:22
 Re: Re: Re: Head Milling Question for VAC in reply to mike, 04-07-2004 18:13:30
Mike,
Wouldn't .125" get into the water jacket? I take it you made your own head gasket? Why copper? One last question, what was the PSI before doing the head work?
mj
04-07-2004 18:27:07
Thanks, Mike...there you go, Smitty. Seems like you can follow Mikes' lead without getting too nervous...Roger?
mike
04-08-2004 04:07:23
 Re: Re: Re: Re: Head Milling Question for VAC in reply to mj, 04-07-2004 18:27:07
Just a note, check the thickness of the metal around the water jacket before you mill.
