Increase RPM=Increased Horsepower...?
Glenn FitzGeral
04-06-2004 19:06:49
Quite commonly tractor companies increased horsepower of a tractor on newer models simply by increasing the engine rpm's. This rather puzzles me as, wouldn't any tractor owner experiment around a little by increasing his rpm's 50 or so to see if it made a significant difference? I know Allis, and IH did this a lot. Case did with the SC in the last two years of production as well as increasing piston size. The VAC was the reverse situation in that the rpm's were dropped so as not to rival the SC for horsepower. There must be more to it than I understand. Anyone care to comment? Thanks, Glenn F.
Roger (Mi)
04-08-2004 04:48:51
 Re: Increase RPM=Increased Horsepower...? in reply to Glenn FitzGerald, 04-06-2004 19:06:49
Yes, increasing RPM will give you SOME additional horsepower but only as long as the increased RPM can be retained. The term horsepower is used as a measurement of work or force. If you can lift 550 pounds of weight 1 foot in 1 second, you're 1 horsepower. If you can lift it faster, you're more than 1 horsepower.
An internal combutsion motor is a heat pump. When things get hot, they expand. When a chamber is filled with air/fuel and it's ignited, the air is heated. As it expands, it forces a piston down which turns a crankshaft. As most good hot-rodders know, there are 3 considerations for greater performance. 1. Volumetric efficiency = getting the greatest amount of air-fuel into the combustion chamber on the intake stroke. After the power stroke, getting the exhaust gases out without a lot of back pressure. (carb, ports, valve size, cam, etc.)
2. Thermal efficiency = compression ratio and a complete burn of air/fuel mixture. (12 parts air to 1 part fuel for the greatest power) (9.3 to 1 compression ratio on regular gasoline)
3. Mechanical efficiency = reducing the friction in the motor. Generally, a longer connecting rod will have a greater mechanical efficiency between the piston and crankshaft. Use a good grade of motor oil. Hope this will give you some insight and ideas.
Steve Lehman
04-07-2004 20:39:51
Here is a question on the VAC speed. I have a 1950 VAC with a M-S TSX597 carburetor, and 2 sets of holes in the governor rod guide bracket. According to the I & T manual, a tractor so equipped is supposed to run at 1880 rpm no load. Since the date on the carburetor is 4-54, it is obvious that the carb has been replaced at one time. Was this part of an update kit that Case had to increase the horsepower of the VAC? Was the TSX597 the original equipment carb on the VAI?
mj
04-07-2004 17:21:02
Along with increased RPM there needs to be changes in cam-lobe profile and timing. The torque characteristics can be changed dramatically by merely changing the cam timing. As was said before all of the engines' components need to be matched to the new parameters for maximum performance. Tractor engines are set up for torque at a certain rpm range for useable power on the farm. Pullers are a whole different deal. All of the VA series ag tractors are set at 1450 no load RPM in order to give 540 RPM at the PTO but the VAI is set at 1900 since its' primary duties did not include PTO work SO turn it up to 1900 and see how she pulls.
mj
04-07-2004 18:33:08
 Re: Re: Increase RPM=Increased Horsepower...? in reply to mj, 04-07-2004 17:21:02
Check the 1425 RPM should be 1600 no load and 1450 full load....forgot my Ginko!
Jerry/MT
04-07-2004 10:41:27
AS stated earlier, HP = Constant x Torque X RPM.
In general, increasing the rpm on a spark ignition engine (gas engine) will increase the HP some until it reaches a peak and then begins to decrease. That's because the peak torque occurs at a significantly lower rpm than peak horsepower. The reason the peak torque starts to fall off is because of increased pressure losses in the air filter, carb, intake manifold, and intake valving as the corrected airflow continues to increase(W x T^.5/P)with rpm. If you want to increase the torque, one can buy a better manifold, a less restrictive air cleaner and carburetor, increase the valve size, port the head, put on a less restrictive exhaust system etc. This will raise the peak torque and the horse power across the board and then allow a higher peak horsepower before it starts to decrease again. Ofcourse the loads on the engine components increase and so engine life can be shortened. There ain't no free lunch. The engine should be designed for the power and torque that it needs for the application as well as the the design life required by the market place. Both requirements must be met at the same time.Hope this answers your question.
Dave
04-07-2004 09:19:15
Yes, you can increase horsepower by increasing rpm. Just change the High Idle point on the govenor. This may be easy and may take major modifications. Now the other questions. Will the engine run reliabily at the increased rpm. You have just increased the forces on the pistons, rings, bearings. Will the valves get out of the way in time(it usually takes a lot of rpm before this is a problem). Will the engine shake itself to pieces?
Do you need to change gearing to effectively use this increased horsepower. Will the gears themselves take the increased power, the bearings?
The whole package should be considered when fooling around with the govenor. Yes the manufacturers got more horsepower by apparently just increasing rpm, but dig deeper and I think you will find a few other changes to make it work as a package.
I heard a story once about Allis-Chalmers suppling engines to a D-21 puller. He came into the plant and the engineers were telling him that he would get so many ungodly horsepower out of the latest engines but that they would only last for 3 minutes. His reply was "Crank them up some more, they only need to last 30 seconds".
brent
04-06-2004 19:59:28
Well, from a technical perspective, horsepower = torque * speed. So, if the speed is increased without a decrease in available torque, the HP would increase.
What is not clear to me is if the available torque would drop off with increased speed, i.e. if the engine is loaded, would the speed drop anyway? I guess the speed governor would also come into play on that as well. One of the mechanical engineer-types would have to comment...I'm an electrical, so I guess I'm off the hook ;^)
Mike's600
04-06-2004 19:41:17
Rpms increase horse power to a point. I pulled a Va1, and turned 2400 rpm, big difference over stock setting.
mike's600
04-07-2004 18:17:54
 Re: Re: Increase RPM=Increased Horsepower...? in reply to Mike's600, 04-06-2004 19:41:17
I used a stiff spring to over power the gov.Just need to experiment with spring rates so the gov will hold it at 2300-2400 rpm
Smitty
04-07-2004 05:34:56
I have a VAC I want to pull, it appears there are some addtional HP if I increase the RPM??? How do I increase the RPM on a VAC?
mj
04-07-2004 17:53:40
 Re: Re: Re: Increase RPM=Increased Horsepower...? in reply to Smitty, 04-07-2004 05:34:56
third party image
Here is the first page...go to image 95 on the link below for the second...click to enlarge.
