case 970 help
harback
04-06-2004 17:59:13
got a question on a case 970 with a 540 pto . is there a way to convert it to a 1,000 shaft, I need to be able to go back and forth . Also what would I need to put a 3 pt on or is not cost effective. thanks for the info.
Jim Handke
04-06-2004 18:28:54
 Re: case 970 help in reply to harback, 04-06-2004 17:59:13
The pto on 770's thru 1175's are reversible shafts. You'll find a snap ring holding the shaft in, remove it, and reverse the shaft. Changing to the 1000 side requires pushing against a spring, so it requires some effort to hold it in while replacing the snap ring. And be sure the snap ring has seated properly, or the shaft will pop out under load. Experience is telling here. As far as adding a 3 point is concerned, you would have to remove the platform to add the load sensing shaft, and all applicable hardware. Labor intensive and who knows what the price would be.
