case rear wheels interchange
Chris Brown
04-06-2004 12:45:58
Will the rear wheels off from a 530 ck fixed axle tractor bolt onto an ag 430 that has adjustable rear end? I can't just go out and measure because the 430 is 285 miles away. Thanks all
JRT
04-06-2004 21:07:33
 Re: case rear wheels interchange in reply to Chris Brown, 04-06-2004 12:45:58
Yes. They both have 6" hubs, however the 430 adjustable is probably 28" wheels where the 530 is 24". Might make the 430 set a little low in the rear unless you put on smaller front wheels.
Chris Brown
04-07-2004 06:53:37
 Re: Re: case rear wheels interchange in reply to JRT, 04-06-2004 21:07:33
Thank you very much. I didn't want to drive 250+ miles just to measure a hub.
