VAC muffler
Mike
04-06-2004 10:51:51
As my VAC doesn't have a muffler, just 2' of stainless milking parlor pipe for exhaust, I'm wondering if anyone has used a NAPA muffler. I have know idea the dimensions of a factory one other than the inlet diam. Anyone know of such an animal?
Joe (Wa)
04-06-2004 17:52:35
 Re: VAC muffler in reply to Mike, 04-06-2004 10:51:51
Take Case p/n A29991 to a Napa store and have them cross it. Someone here posted Napa p/n 21039 as cross for 300 series, it is the same muffler. If you really need dimensions I will measure mine. Joe
C. Amick
04-06-2004 14:09:21
S t a n l e y Muffler Co. makes replacement mufflers for almost any farm tractor. you can find them at farm stores or from V a l u - B i l t Tractor Parts for $18.99 for a VAC. I just put one on my VAC.
Art
04-06-2004 11:12:31
Mufflers are still available through your local Case/IH dealer for the VAC.
Mike
04-06-2004 11:47:31
 Re: Re: VAC muffler in reply to Art, 04-06-2004 11:12:31
i'm sure they are, but if they are anything like axle seals, they are 4 times as expensive.
Martin in DE.
04-06-2004 13:28:14
 Re: Re: Re: VAC muffler in reply to Mike, 04-06-2004 11:47:31
Mike,OEM may cost twiced as much as what Cental Tractor used to sell but last 10 times as long.
Russ
04-06-2004 15:03:42
 Re: Re: Re: Re: VAC muffler in reply to Martin in DE., 04-06-2004 13:28:14
VAC MUFFLER; If an OEM muffler lasts 10 times longer than others it must be galvanized dipped.
Mike
04-06-2004 13:36:48
The only reason I say 4 times as much, My grandfather used to buy lots of bearings and seals for his equipement at the feed store and we found the seal here for $10.00. the seal from the dealer is $41.00.
I will probably continue using the straight pipe until the neighbors complain about the noise. :)
Les...fortunate
04-07-2004 17:20:21
 Re: Re: Re: Re: Re: VAC muffler in reply to Mike, 04-06-2004 13:36:48
I have no muffler on my VAC and I don't think it's the noise the neighbors don't like. They might object to the blue smoke though.
