Hydraulics
William Montgom
04-06-2004 08:56:10
My brother has A problem with his Case 430 tractor The hydra. oil don`t return through the filter to the sump so it fills up the rear and fills up then comes out the vent I have had the control apart and cannot find any reason Has any one come across this problem and what was the fix my brother thinks I can fix any thing so I would just like to keep him thinking that William Montgomery 304 675 5934 [email protected]
Dennis/Ohio
04-07-2004 23:42:42
 Re: Hydraulics in reply to William Montgomery, 04-06-2004 08:56:10
Hi, The only two things I know of is either the lift cylinder for the 3-point is leaking into the final drive or the seal is leaking between the 4 speed and torque tube. Hope that helps, Dennis.....
