Value of 1941 Model S
Lee Aanderud
04-06-2004 06:11:37
I have a chance to buy my grandfather's Model S Case tractor back (Serial: 4503645). The engine is not stuck and the tractor has been covered and set up on blocks since being sold back in the mid-1980's. Prior to that it sat for about 5-8 years. We used to use it up until about 1980 and had to start it with the hand crank as the battery was gone and the battery tray was pretty much gone. This is up in North Dakota and has 99% surface rust but no major rust through. The seller isn't sure what it's value but gave me a price of $2200. It's worth that much for sentimental value alone, but seems high for a non-running tractor. If I remember correctly the tractor is complete minus the headlights. Any help as to what a fair market value for this would be appreciated... I think the seller bought it from my grandfather for less than $500.
caseman-d
04-06-2004 11:46:58
 Re: Value of 1941 Model S in reply to Lee Aanderud, 04-06-2004 06:11:37
I guess I would make sure the engine turned over and loosen the oil drain plug for antifreeze. The Case S is getting more popular but without seeing pictures of the tractor I would say 800.00-1200 for it. 2200 is even high tor a restored one.
caseman-d
Art
04-06-2004 06:38:34
Personaly, I wouldn't give more than 3, or 400 for a non-running tractor, cause you have no idea what your going to go through to get it to run again. You'd be hard pressed to find to find somebody to pay $2200 for one that runs....Some S part are very hard to find....
