PyroMeter ???
Joe
04-05-2004 07:14:03
I have a question on what the heck is and do I really need a working PyroMeter. We just got our 1270 From JayCox Impl. in Iowa and was very very pleased at the way they handled the sale of this tractor over the internet and phone. Anyways, I dont think the pyrometer is working. This is our first tractor with a turbo... I think the pyrometer reads the intake manifold air to the turbo so it doesnt get to hot and melt - 1500 Degrees is max. Anyways, the meter is stuck all the way to the right and does not move. We knew that it didnt work when we bought the tractor. So do I really need a working PyroMeter ?? How hard is it to change, what should I check and is there any handy directions to access ? Sorry for the long post. Thanks for all your input.. Joe
PS.. What does a Pyrometer cost and is there a good cheap source for one ?
JCMarleau
04-06-2004 20:08:11
 Re: PyroMeter ??? in reply to Joe, 04-05-2004 07:14:03
I may help you with a good used one if you don't find any. my e mail is [email protected]
erndog
04-05-2004 19:46:05
just put a pyrometer on a tractor i turboed. the thermocouple and a 6 ft long lead was about $35 at the local over the road truck place. I had a good gauge so didnt need one, but the parts man told me a new one was around $90. Nice to have but probably really do not need it. good luck.
Shane
04-05-2004 15:18:35
No you don't have to have a pyro but they are nice. It was an option on the 1270-1570's. If you are overworking the engine the pyro will let you know in a hurry. Yes you can still get one, I assume you can even get the OEM replacement from Case. Or you can go to almost any diesel or truck shop and get one. Heck, I have even seen them on EBAY.
Roger
04-05-2004 11:09:05
Joe, a pyrometer measures exhaust temperature. It is a good tool for seeing a potential problem brewing or letting you know there already is a problem. I have a 1370 with an M&W pyrometer in it, last fall when I was plowing, some corn trash got in to the strata-tubes that pre clean the incoming air, tht tubes plugged & the engine could not get enough air to run cool & clean, it started pulling exhaust backwards from the muffler which meant the air filter clogged up with diesel soot. When I would blow the soot out, it would run cooler for a while until the filter filled up again, after the second time, I got new filters & removed the rubber seal ring from the outer filter so it could draw air in where the ring was, after that it run the rest of the fall with no more problems. Mine runs around 1000-1100 degrees when pulling. I don't know if M&W pyro's are made anymore but there are places around to get a pyro, Midwest Diesel at Fort Dodge Iowa has some but they are smaller than M&W. Maybe truck repair shops or truck stops may have them. If I can find one I will put it in my 4440 Deere so I can keep an eye on it too.
Wide Open
04-05-2004 18:50:45
 Re: Re: PyroMeter ??? in reply to Roger, 04-05-2004 11:09:05
Roger, you mentioned that your 1370 runs 1000-1100 degrees when pulling. If that is the CASE(haha) you are really takin a chance on doing some damage, Max. operating temp should be 1050, anything after that and you could be doin some damage, you might want to shift her down a gear, so it will run cooler. Also, you should always let it cool to 550 or lower before shutting down. On my 2470 when you pull it good, it will run 850-950 max, which is right where it should be. --Wide Open
Jim Handke
04-06-2004 06:04:39
 Re: Re: Re: PyroMeter ??? in reply to Wide Open, 04-05-2004 18:50:45
Just wondering if you got the bugs out of your rear steering on your 2470?
Roger
04-05-2004 22:12:50
This tractor has always run that way, I bought it used & it was used a lot to grind feed, I went to the field & found out that the air filter was plugged tight, it ran around 14-1500 degrees even after changing filters even though the exhaust cleaned up a LOT. I had to get it overhauled later & found out why the exhaust always ran high, previous owners must have used a lot of ether to start it because there was not 1 piston ring in it that wasn't broken but it did NOT use any oil, NO KIDDING. After the overhaul it had very little blow-by coming out the vent tube, before there was almost as much out the bottom as the out muffler. I wish this one would run 850-950. Guy over at Midwest Diesel said that these never had anymore than enough air filter capacity. I always cool it down to 400 before shutting it down, I had to replace the turbo & Midwest Diesel guy said it showed signs of hot shutdown before I got it. I look back & wonder if I should have left it on the dealer lot, but after getting some bugs out of it, it's been a good old tractor.
