Any way to convert 1070 remote valves to float?
dudley
04-04-2004 18:00:49
Using tractor with highway department snow plow and need a one remote valve to have a float position to remove the pressure on the hydraulic angle cylinders so the lock will engage. Any semi-simple solutions or is it possible? Thanks for any help.
Brent Behner
04-05-2004 11:51:33
 Re: Any way to convert 1070 remote valves to float in reply to dudley, 04-04-2004 18:00:49
Dudley, Remove Allen Head Plug Left Side Of P.T.O. Housing. Install Street Ell & Hose With Male Quick Coupler, Hook Quick Coupler To Top Left Female Coupler. Hook Hose From Cylinder To Top Right Coupler. Move Lever Fordward To Have Float. Brent
dudley
04-05-2004 12:17:46
 Re: Re: Any way to convert 1070 remote valves to f in reply to Brent Behner, 04-05-2004 11:51:33
Thanks but i need pressure in both directions to turn the blade in both directions.
DKase
04-04-2004 20:06:34
There is no float position on my 970, but if you move the lever just a little either way from the hold position it will release the pressure without building return pressure. LOL DK
