MY PRIDE and JOY S C
Elliott from IL
04-04-2004 17:45:46
I hope this works. I just got done with the S C Case all but wiring. I just gotthw wiring in from Brillman Co. It does have a wire for the back LIGHT. Still don't know what light to use (4 3/4 or 5 1/4 inch ??) and where to put it. I sure would like some help on this if someone has 2 cents worth. Thanks Elliott from ILL
Robert Pence
04-05-2004 07:07:32
 Re: MY PRIDE and JOY S C in reply to Elliott from ILL, 04-04-2004 17:45:46
third party image
Here's a photo of Dad's 1947 SC, taken about 1948. It shows the rear light.
That's me on the tractor at about age nine. I wasn't strong enough to engage the clutch with by hand, so I used my foot. To disengage it, I'd yank with all my strength.
My aunt, Dr. Jeraldine Baumgartner, took the photo using a Leica 35mm camera and Kodachrome 10ASA(ISO)
Bob Pence
Robert Pence
04-05-2004 06:51:10
Dad's 1947 SC didn't have the combination (cultivating/tail) rear light. The rear light was the same as the headlights, and it was attached with a bracket bolted to the end of the seat support.
Dad's 1951 SC did have the combination rear light.
Elliott from ILL
04-04-2004 19:38:55
Thanks DCTOM. Thanks Brent. Now someday I'll get a picture of it on here I hope. When I learn how to do it.
dctom
04-04-2004 19:20:16
CONGRATS ELLIOTT, KNEW YOU WOULD GET HER GOING DCTOM
Brent
04-04-2004 19:04:01
The back light on our 49 SC is 4.75". It's a special light that has a switch on the teardrop housing, and the switch has 3 positions - off, cultivating light, and red (tail) light for road driving.
The rear light is mounted with a bracket that hangs off the seat bracket, if memory serves me well. The light switch will power that wire you mentioned in your post.
