snow removal
Mike
04-04-2004 11:59:54
I have a long gravel driveway. Been using a rear blade for snow removal. Would a front loader work better?
C. Amick
04-05-2004 09:33:21
 Re: snow removal in reply to Mike, 04-04-2004 11:59:54
I think the "rear blade" will work better than the "front loader". I use a rear blade, but a front blade definitely has a rear blade beat. My neighbor has a Farmall Super A with a front blade and lots of weight on the rear and he can do the job quicker and not have a stiff neck from looking back after he is finished.
Glenn FitzGerald
04-04-2004 16:25:23
I agree with the snowblower concept however, a good sized blade mounted to the loader works pretty good too, provided you have some open area to push the snow.
Elmer
04-04-2004 13:35:09
Snow blower is the only way to go.
Russ
04-05-2004 16:43:53
 Re: Re: snow removal in reply to Elmer, 04-04-2004 13:35:09
Blade or Bust; A front snow blade is good. Must push back early so you don't get snowbound.
Snowblower is better if you don't have 1500 foot
of driveway. Better still, go to Florida or New Mexico for snowflake avoidance program.
Old Milkmaid
04-29-2004 18:08:59
 Re: Re: Re: snow removal in reply to Russ , 04-05-2004 16:43:53
It's 4-29 and still snowing in Colorado! Our DB990 is sitting 3-legged in the front yard where the left-rear wheel fell off last Friday, in the midst of 2.5' of snow! Two of the "jack screws" (Case part# A9407) broke or sheared, and the other three couldn't hold it on. At least it happened in the front yard, not half a mile away, blocking traffic on the ranch road! We have a front bucket and big back-blade, and use the blade for most of the snow-removal. Only when it's really deep and really wet do we have to use the bucket, and even then it's easier to turn the blade around backwards and push the stuff, rather than pulling it off the road by going forwards. That's how I moved the remains of the seven-foot snow we had in March last year! Slow, but it worked!
