Need a 530 measurement
Old Eb
04-03-2004 15:13:28
I purchased a 1968 Case 530 (agric. model) this winter and can't find the answer in my manuals, so maybe someone can provide the answer. Doesn't seem like the draft arms lift high enough - certainly not as high as the other tractors I have. Everything else about the draft system seems fine. Would like for somebody to measure the height of their draft arms at full up? Also please let me know what size tires you are using. Thanks much in advance.
third party image
Illini Case
04-04-2004 18:12:36
 Re: Need a 530 measurement in reply to Old Eb, 04-03-2004 15:13:28
My 1961 530 diesel has 14.9x28 on the rear and 5.50x16 on the front.
Brent Behner
04-04-2004 09:46:26
Eb Is 530 D.O.M. Or Eagle Hitch ? If D.O.M. Raise Draft Arms Up With Hyd. Lever All The Way. Measure Distance From Ground To Center Of Ball. Manuly Lift Arms Up Until They Stop & Measure Distance From Ground To Center Of Ball, Should Be 1 1/2 To 2 Inches Difference. To Raise Arms Losen Lock Nut On Spool Shaft & Turn Spool Counter Clock Wise. Raise & Lower A Few Times & Recheck. If Adjusted To High Can Cause Internal Breakage. Must Have Free Play. Brent
Old Eb
04-04-2004 17:14:26
 Re: Re: Need a 530 measurement in reply to Brent Behner, 04-04-2004 09:46:26
It is a D-O-M. I will try that procedure. Thanks.
third party image
