Help all you powershift guys
Allan C
04-03-2004 12:04:05
1070 has following symptoms. When you take your foot off the "inching pedal" it loads the engine quite noticeably, as soon as you push it down a little it runs freely, If you depress it all the way it will kill the engine (when cold) just loads it when warm. Reverse doesn't work either. The Mechanics are good. It's in the hydraulics. where?
Brent Behner
04-04-2004 10:28:52
 Re: Help all you powershift guys in reply to Allan C, 04-03-2004 12:04:05
Allen C. Can Be Broken Clutch Parts In Trans. Can Be Stuck C3 & C1 Clutch Pilot Spools In Power Shift Valve. Can Be Wrong Bottom Power Shift Valve GASKET. If This Will Help 1 ST Power Shift C1&C2 Are Powered. 2ND C1&C3 3RD. C2C3 Reverse C2&C4 Pedal Down C4. Clean Spools & Bores 1ST In Valve. Get Service Manual To Help You. E Mail Back If It Doesn"t Work Brent
Thad
04-03-2004 15:09:22
Sounds like a valve stuck in the powershift control valve. Thad
Allan C
04-04-2004 12:48:25
 Re: Re: Help all you powershift guys in reply to Thad, 04-03-2004 15:09:22
Thanks guys. I'll start with the valve body and see what I can find.
