Loader bucket float position
Mike Fallavolli
04-03-2004 10:40:41
I'm a new owner of a 530-CK and reading the manual it talks about the float position of the front bucket for grading...something I need to do. Unfortunately my control lever doesn't seem to go into the float position but I'll deal with that.
What I'd like to know is what exactly does this do and how does it work. I assume that the hydra-leveling cylinder comes into play here.
I just want to understand the workings of this thing so I can make the most use of it.
Thanks as always.
-- Mike
Dennis/Ohio
04-08-2004 01:17:08
 Re: Loader bucket float position in reply to Mike Fallavollita, 04-03-2004 10:40:41
Hi, It can also be used for stripping top soil in forward gear. This is the hard one for me. You control the depth of the cut by the angle of the leading edge. It works great but I need to rig-up a bucket angle gauge. I usually go too deep before I turn the leading edge back up. My manual shows a "bucket sight leveling gauge" as factory equipment but mine doesn't have it.
Best wishes, Dennis.....
Paul Janke
04-03-2004 17:42:05
Float position is usually all the way forward on the lever. It usually if not always has a detent so it will stay there until pulled back. The lever feels like it is all the way, it requires pushing the lever harder to go to the float position. Float is just what it says. The cylinder controlled by the valve is not held in any position. Both work ports and the return to tank port are interconnected.
Jim B
04-03-2004 17:37:38
Not as complicated as you may think. The loader spool valve (not the bucket) is detented into a past-forward position which dumps all hydraulic pressure to either side of the lift cylinders. This allows the entire loader to drag on the ground due to it's weight. The bucket remains position wherever you positioned it because that valve is operating normally. The idea is > the bucket can be positioned so the bottom is flat on the ground to smooth reasonably good > or you can tip the bucket so the leading edge is biting the ground and then run the tractor backwards to cut a little as you drag. Hydra-leveling cylinder has nothing to do with the float function. It simply functions as a pump when you raise or lower the lift to reactively push fluid into or out of the bucket cylinders to make the bucket stay positioned relative to the lift position.
