Who would have thought !!!!!!!!
Bob/wis
04-03-2004 08:07:43
Well yesterday I dropped the pan on my 930 to find the cause of sudden low oil pressure last winter. It was parked after the drop so not to damage anything. Well I found the most unbeleiveable thing. I bought this tractor about 5 yrs ago at a auction. The old guy that sold it said it was rebuilt by him a few yrs before hand. No problem got it cheap (1250) it looked bad , was painted like a massey with a paint bruch and barn red paint. Well low and behold there was 2 main caps just hanging there. Finished unbolting them and checked the crank and bearings. Every thing was great. Just rebolted them torqued them down and checked the torque on every thing else under there and bolted the pan back on. Put oil in it and fired it up. Now its got 40 warm idleing and 50 run at pto. Man that was lucky is all i can say. How did that thing stay together this long like that i do not know.
Later
Bob/wis
CASEPOWER
04-03-2004 13:53:58
 Re: Who would have thought !!!!!!!! in reply to Bob/wis, 04-03-2004 08:07:43
I have seen two engines recently that have blown. Both came through the side of the block. Both has a rod nut missing from the rods. They had to run for a little while while the nut was working its way off. One even bent the push rods from the piston coming up to far and hitting the valves while running. He changed the push rods and it lasted another 5 minutes before it threw the rod. You was just lucky to find and fix the problem. Lucky you!!!
dctom
04-03-2004 12:21:36
HE IS "CASE TOUGH" ONLY REASON IT LIVED DCTOM
Jim Handke
04-03-2004 09:11:06
Were the rods torqued right? I wonder if he just missed two, or if his torque wrench was bad.
Bob/wis
04-03-2004 11:04:56
 Re: Re: Who would have thought !!!!!!!! in reply to Jim Handke, 04-03-2004 09:11:06
Every thing else rods and mains was fine. It was so strange that just them 2 was loose. Beleive me I checked them and rechecked them before that pan went back on. When I do a rebuild I am always affaird of missing one. So, I try to torque the caps the last thing for the day. Then I lay the torque wrench on the block, next morning I go through and recheck them when I pick the wrench up to move it. I use a click type torque wrench all the time.
Bob/wis
