farming with CCs
okla/kans Bill
04-02-2004 18:51:31
Well since ive recieved a few responses to my first question, ill ask another. When plowing and discing with a CC, did you put her in first and open the gas all they way back and start plowing or discing, or did you put her in second and let the gas be open just enough to pull the plow or disc. The reason Im asking, is ive always put her in first and pulled the gas all the way back and fight overheated radiators all the time. This last winter, when I fall plowed, I put her in second and used just enough gas to pull the load at a slightly slower pace than described above, but went much faster in the long run du to the radiator not overheating. I have a new 4 core radiator, but it has some rust in it from the tractor engine. I have a DC engine on it now, but, I was wondering hw it was done when the tractors was relativly still in there prime. I can see putting her in first for other lighter jobs like mowing when you want a somwhat slower travel speed to a high pto speed. at least with pararie hay which has no stem like alfalfa or clover. Or planting in first to go for straight rows, but I think ill try second this year. Figure it might save gas. Let me know your thoughts, and thanks for the response
Bill
04-03-2004 10:31:03
 Re: farming with CCs in reply to okla/kans Bill, 04-02-2004 18:51:31
Our family cc use to pull a 3-14,s plow and in the lighter ground a 3-16,s. The disk dad had was a 8 foot tandem non wheel disc. Dad said it never ran hot. He ran in second gear lower rpm on the plows, but had to use first with the disc in sod fields for the first pass.If he wanted to make the tractor pull better, he would use straight gas. and not run it on fuel oil.After I bought it back from the dealer it would over heat. Someone had stolen the rad. cap off of it when it sat at the dealers lot. You need to check the timing and clean the rad, and clean out the block, the cc,s will build up with rust around the 3rd and fourth cylinder sleeves. I have been told by more than one person that they cleaned out over a 5 quart pail of rust out of these engines when they pulled the back two sleeves. Email me if you have more questions Bill from Wisconsin
Bob
04-02-2004 19:58:45
Bill
First we had implements matched to the tractor. We pulled a heavy disk plow with a 6 foot cut in heavy black soil. The sowing 'combine' was about 8 feet wide. It had light 'bridle' linked tines (each tine linked to two others) by rods, chains and levers. A scarifier (similar to chisel plow) was about 6 feet wide.
These impliments were pulled in third gear. Dad and Uncle had to get over the gound as they were farming 1000 acres with C and L.
We started the engines on petrol (gasoline) and switched to kerosine as soon as the engine was hot enough (about 5-10 minutes work). The radiator curtin was kept closed until the engine was hot.
The curtin was adjusted to keep the engine hot but below boiling. We could work the tractors heavily in summer temperatures of 110-115F in third gear without boiling. The tractors were always well maintained.
All the family members switched to Case tractors in the 1920s and 30s. Before that they used horses and a few early Fordsons. One Uncle (still living) told me that the Cases were way better than the Fordsons for many reasons, but one of them was that they could never stop the Forsdons boiling whereas the Cases never did boil.
If your tractor is boiling in light work, you must have a problem in the cooling system or the spark is not timed right or the mixture is wrong.
Bob
okla/kans Bill
04-02-2004 20:23:46
 Re: Re: farming with CCs in reply to Bob, 04-02-2004 19:58:45
I dont know if ou would call pulling a 2/14 plow or a 16ft disc in sandy soil light work or not. I know that up home. near St Joe Mo, which, I guess means nothing to you, my grandad pulled 3 14s with it in hilly ground, but the ground was loam, not sandy, and the tractor was 70 yrs younger
Bob
04-03-2004 00:19:01
 Re: Re: Re: farming with CCs in reply to okla/kans Bill, 04-02-2004 20:23:46
Bill
I know the general country side and soil in Missouri as I did my PhD at Uni of Illinois, Champaign-Urbana. I traveled through a lot of farming country in USA and Canada just to see what it was like.
Our soil in Northern NSW is a bit like that around Urbana, but a bit heavier. Unfortunately, we have nothing like the rainfall of the midwest of the USA. Our climate is very variable; either drought or flood.
Bob
Dave Olson - Illinois
04-03-2004 18:11:32
 Re: Re: Re: Re: farming with CCs in reply to Bob, 04-03-2004 00:19:01
Hello Bob,
Champaign County Willard Airport had over 7" of rain last month. Average for this area is a little over 3" for the month of March.
We've had sunny, windy & warm weather the past few days so folks should be able to get into the fields next week.
Spring is breakin out all over here in Central-Illinois. Happy Spring everyone!
Dave Olson - East Central Illinois
