John deere G vs. the Case DC
RedandGreen
04-01-2004 15:53:15
Ok how did the G compare to the DC. I guess comparing the DC to the A was realy not a fair comparison becouse the A was was more comparable to the SC (I think) correct me if I'm wrong. Whats your thoughts and experances in running the DC and then comparing what it was like to run a john deere G
Gene Dotson
04-01-2004 18:41:45
 Re: John deere G vs. the Case DC in reply to RedandGreen, 04-01-2004 15:53:15
Based on the Nebraska test results, this should be a close match. shipping weights, horsepower and pulling power are very close. However the only DC was tested in 1940 with an all fuel engine at slightly over 35 horsepower and the G was tested in 1949. By 1949 DC's had increased the bore size to 4.00 inches with gasoline manifolds and compression. My 1950 "D" dynos at 44 horsepower and I would believe that is a common power on most of them. I would say the DC would do more work in the same day and use much less fuel. The G was built only in the low fuel capacity to burn kerosene or distillate fuel. I grew up in the 50's and we had a strong Farmall H that would outwork our neighbor's G all day long.As a disclaimer, we are only talking stock factory tractors, except for the "H"... Gene
jb
04-02-2004 06:26:42
 Re: Re: John deere G vs. the Case DC in reply to Gene Dotson, 04-01-2004 18:41:45
Most JD G's were converted from "all fuel" to straight gas burners. Also, many were were bored out as well. Most G's I've seen or used, at least the later ones, had 45 to 55 hp. We had a '37 G one time that had 75 hp on the dyno, but you could never keep the fuel tank full.
CASEPOWER
04-01-2004 16:51:45
About $3000 difference.
dctom
04-01-2004 16:11:34
CLOSE TO SAME G A LITTLE SLOWER IS ALL BOTH 3 PLOW UNITS RIGHT?
OOHNDEERE_JOHN
04-02-2004 10:25:46
 Re: Re: John deere G vs. the Case DC in reply to dctom, 04-01-2004 16:11:34
Still remember when John Deere in 1952 offered for $107.50 would pick up your Model G and change pistons to high compression cast iron but around 6 to 1 and put on a gas manifold. My dad had his 1950 G done at that time. 38 hp before and around 50 after wards. Those who complain about the gas used by a G never bother to tell the differce of work done after. When we got our work done I went to help neighbors who had the DC`s and they pull a plow the same as the G. Jon
ps: sometimes you have to look at results and forget the color. ( both were good tractors)
