SC Front Spindle Question
C. Amick
04-01-2004 09:21:41
I have a narrow front (2 wheels) SC that has a lot of vertical play in the spindle. The spindle sticks up too far for the nut and washer on top to tighten against the housing. Took it apart, can't see any evidence of a bearing. Planning on building up the space on the inside with washers to push the spindle down to where it is supposed to be. What is supposed to be around the spindle, some sort of spacers?
Klyde
04-01-2004 10:39:57
 Re: SC Front Spindle Question in reply to C. Amick, 04-01-2004 09:21:41
A thrust bearing I think its a timken T139
Dave
04-01-2004 10:59:52
 Re: Re: SC Front Spindle Question in reply to Klyde, 04-01-2004 10:39:57
Hello,
Klyde is correct the case number is 04271AB thrust bearing timken NO# T-139
there is also a collar case #04250AB This is a steering spindle bearing collar.
Daveinwisc
