VAC or VA? Or VC?
Haycreek MN
04-01-2004 04:55:51
In regards to a earlier post about the difference between a VA & VAC, My neighbor showed me his VA, the serial number tag started with VC, was this another model or did they just omit the "a", curiosly concerned,,,, thanks for any info, B
Roger A. NY
04-01-2004 06:14:24
 Re: VAC or VA? Or VC? in reply to Haycreek MN, 04-01-2004 04:55:51
If the tractor had a flat head Continental engine it would be a VC or at least of the V series. If the engine is a valve in head it would be a VA series ie VA, VAC, VAI,or VAO. I have seen tags that have been changed. Roger
Kirk-Tx
04-01-2004 05:50:52
Someone will correct me if I'm wrong,but a VC was built in 41 & 42. Because of the war, they used parts from different companies. Continental engines and a different transmission. It is different from a VA.
