Rebuilding VA Engine
BOB
07-12-1999 20:34:00
I'm putting together my 1948 VA. After torquing down the main bearing and connecting rod caps the engine is very hard to turn over with a wrench. Is this normal? It will go all the way around but it takes almost every effort to turn it, it seems real stiff. IS this normal???
wayne
07-12-1999 21:46:15
 Re: Rebuilding VA Engine in reply to BOB, 07-12-1999 20:34:00
Loosen all bearings and check each one, one at a time to see which one is making it hard to turn. If it is all of them, then you must have .001 or .002 undersize bearings. (assuming there are inserts) DO NOT ATTEMPT TO RUN THE ENGINE OR IT WILL SPIN A BEARING.
