LA bore stroke questions
SmartAxe
03-31-2004 17:50:09
I know the bore is 4 5/8, but how long is the stroke on an LA CASE?
To build a DC puller, my question being is this... I've been told the biggest you can bore a DC block to is 4 5/8 before hitting the water jackets. To keep the engine reliable 4 5/8 inches was recommended as being the largest you should go with it. Would a engine kit for an LA work well in a DC block, or is the stroke for the LA too much or too little? Or is something else recommended to gain the extra HP?
Thanks,
-Mark
CASEPOWER
03-31-2004 19:59:26
 Re: LA bore stroke questions in reply to SmartAxe, 03-31-2004 17:50:09
A LA has a 6" stroke. A D series is wet sleeve and you can't bore it big without putting in bigger sleeves. 4-5/8 is easy. Theres one running 4-7/8" bore with 1/8 thick sleeves. You can stroke a DC to 6-1/2 without a lot of clearance trouble and it's not much harder to go 7" stroke. If you use the 4-5/8 LA sleeves chances are you will need to turn the outside diameter down anyway.
SmartAxe
04-02-2004 06:35:17
 Re: Re: LA bore stroke questions in reply to CASEPOWER, 03-31-2004 19:59:26
Hey Casepower,
Do you know a good, reputable source for stroking the crank? I'm sure you do, as I've seen pics of your CC you've built. We've got a 50 DC-4 to do what we want with, and I was thinking of making it turn some heads and people take notice when it's play time at the track. Hardly anyone playing with Case rigs up in my neck of the woods. If you have some good specs for building a DC engine for pulling, I'd love to hear from you. Drop me an email as I've included my email address this time. "Thad" on this board had some ideas a while back, but every time I tried to send him an email it got returned to me as undeliverable.. Thad, you still around?
-Mark
Mike's600
03-31-2004 18:26:43
If you are going to build a puller, used the LA.
More power and you can pull it in most of the same weight classes the DC pulls.
