John deere A vs. the Case DC
Redandgreen
03-31-2004 09:07:24
I was reading the farmall M vs the DC and am wondering how did the JD A compare to the Case DC and the farmall M
Russ
04-01-2004 13:54:56
 Re: John deere A vs. the Case DC in reply to Redandgreen, 03-31-2004 09:07:24
Case DC; Wrote the Deere John letter "Your a big dog John but don't get off the porch because I am your bone crusher. For the longest time DC taught big John a lesson in modesty. So many times bystanders watched as Big John Deere A failed the challenge and was seen departing the field with its drawbar between its legs. DC rules.
fixerupper
03-31-2004 20:42:35
When the DC was tested in 1940, the A only had 29 horses. It wasn't until 1947 that the A's HP had been increased to 35.81. An interesting note is the maximum drawbar pull. The DC pulled 4128 LB with 15.88% slip at a 7010 LB test weight. The A pulled 4110 at 13.03% and 6410 LB in 1939.
In 1947 the A pulled 4030 LB, no slippage listed, and it weighed 5228 LB with no added weights. Their actual performance in the field was probably different from the Nebr. tests. As a kid I remember the neighbors claiming the DC had more guts than the A.
CASEPOWER
03-31-2004 20:03:41
A John Deere?? What's that?? That must be one of them off brand tractors. I think I have seen a couple of them, but can't remember what they look like. What color are they?? HeeHee
Wayne
03-31-2004 17:28:19
John Deere A Neb. test # 384 Dbr 35.30
Case DC Neb. test # 340 Dbr 34.08
JD rated eng. RPM's 975
Case rated eng.RPM's 1100
dctom
03-31-2004 14:03:52
NO COMPARISON UN LESS YOU OVERSIZE AND STROKE THE A
GeoMo
03-31-2004 12:05:47
The A is green with envy.
Knows All
03-31-2004 11:12:45
Every 40 hp competitor paled in comparison to the DC!
