VA or VAC
David
03-30-2004 18:52:55
What is the difference between them? How can you tell? One around here, owner says va everyone I talk to say it sounds like a vac. Don't know who to believe.
C. Amick
03-31-2004 13:37:13
 Re: VA or VAC in reply to David, 03-30-2004 18:52:55
I don't think the VA has the square opening up front for the cultivators.
mj
03-31-2004 06:48:16
Click on link then click to enlarge an image.
JRT
03-30-2004 20:50:48
One way to tell is by the height of the tractor. The V A sets low to the ground where the VAC was a taller model. Also the VA all had wide front ends which did not adjust and larger front wheels and tires than the VAC. The VA was more of a Standard type model and the VAC was more like a row crop.
chopper
03-30-2004 19:00:27
I have a 53 vac, the silver serial number plate on the dash says case vac, I would imagine what the serial number tag says then thats what it should be
