Case SC 6 volt generator
Dave
03-30-2004 10:31:22
Hello all,
I just had my generator rebuilt, I put the meter to it to see if I have voltage. NONE.
Do I have to polarize the generator, if so how do I go about doing it.
Thanks,
Dave
todd hamilton
03-30-2004 18:51:36
 Re: Case SC 6 volt generator in reply to Dave, 03-30-2004 10:31:22
Don't thank me, thank the great Mr. Mike Schotte. Much debated on this board earlier this year but all SCs came from factory negative ground as they were all built in Racine. You may want to make very sure about polarity before damaging your generator or starter. I converted mine to 12 volt and have never regreted it - no problems, always starts even below zero.
Elliott from ILL
03-30-2004 16:21:00
If you need a wiring Diagram give me your email address and I'll send it.
Larry Holder
06-19-2006 17:06:06
 Re: Re: Case SC 6 volt generator in reply to Elliott from ILL, 03-30-2004 16:21:00
Please email me a wiring diagram also. Thanks!!
[email protected]
Joe Love
06-05-2006 07:31:06
Hi, I need a wiring diagram for a 49 SC standard 6V system. Thanks.
[email protected]
C. Amick
03-30-2004 12:23:47
The voltage regulator needs to be polarized, but not the generator. 1st. check the generator. Are you getting power to the generator from the battery to energize the fields? With the tractor running, take the generator field wire loose from the regulator and ground the field wire against the block and check the output on the ammeter wire.
Dave
03-30-2004 12:36:42
 Re: Re: Case SC 6 volt generator in reply to C. Amick, 03-30-2004 12:23:47
Ok here goes,
I didn't power up the generator. My tractor doesn't have a mag, so do I just run the wire from the generator output to the amp gauge then to the negative terminal? Because it is a poisitive ground.
what about the condensor, how does that go in the scheme of things?
I do have a manual, but the wiring diagram is kindof messy.
Thanks to all
Dave in wisc
