VAC spring tune-up
nebraska carl
03-29-2004 12:37:55
To change from 6 volt to 12 volt system is that battery, coil, distributor, generator, and starter all that's needed? Also, the rear axel leaks both sides. Is that a 40 dollar seal kit for both sides? thanks
Barry F
03-30-2004 05:30:26
 Re: VAC spring tune-up in reply to nebraska carl, 03-29-2004 12:37:55
I am not an expert, but I�ve gotten a lot of help here, so I�ll try to answer your question.
To go from 6 to twelve volts, you do not need a starter, the one that is there will work fine.
Ditto on the distributor, it will be fine.
You need a 12v battery.
You need either a new 12v coil that says no resistor needed, or a ballast resistor added before the one you have. I am pretty sure that you can get either of these from Tractor Supply. There is a good diagram of changing to 12v somewhere in the tech tips in this page, maybe in the Ford section. It is not a bad job, but there are several steps that could confuse you, mostly about the light switch, which was an important part of the charging system, but won�t be anymore. Lately I do it by parking a tractor that�s already done next to the one that needs to be done.
Just a few months ago I replaced the seal on one axel on my VAC. It wasn�t a bad job. Pull the tire, and then the star. Then you can see the seal. Drill some holes in the seal, screw in some big sheet metal screws and pull on them. You will get out a big thick seal. Take it somewhere, and they will give you a puny thin seal to replace it, NAPA will do. Get double the number, if you are doing both axels, get four. Tap two into each side. They will do a good job and last well. If you don�t have a torch and big wrenches, borrow them. A really big hammer will come in handy.
carl from nebraska
03-31-2004 04:23:59
 Re: Re: VAC spring tune-up in reply to Barry F, 03-30-2004 05:30:26
thanks Barry F
