plowing with Case 310
Terry
03-29-2004 12:25:03
I am thinking about attaching a 3 pt two bottom 16inch dearborne moldboard plow to my 310 to plow about 2 acres to seed into grass.
Had the 310 for 20 years never plowed with it.
Anyways I think I can pull it okay (sandy loom type of soil), my question is am I going to have to have some weight up front, my rear tires are already loaded. Any thoughts?
Terry
JRT
03-29-2004 21:06:11
 Re: plowing with Case 310 in reply to Terry, 03-29-2004 12:25:03
If your rear tires are loaded, all you need to do is hook up the plow, get it adjusted right, and plow. In a sandy loam soil, that tractor should pull a 2 bottom plow in first gear easily. Might even pull it in second if you do not have any rock in the soil.
Terry
03-30-2004 11:40:53
 Re: Re: plowing with Case 310 in reply to JRT, 03-29-2004 21:06:11
How do you know when it is adjusted properly?
JRT
03-30-2004 21:05:40
 Re: Re: Re: plowing with Case 310 in reply to Terry, 03-30-2004 11:40:53
You want both points on the plow plowing at the same depth in the soil. You do this by adjusting the 3-point hitch at two places. The right arm should have an up and down adjustment controlled by a hand crank. The right arm is typically adjusted munch lower than the left for plowing. Also you adjust the depth of the rear plow with the top link. Typically you lengthen the top lengthen the top link to get the rear plow to go as deep as the front one.
Haycreek Mn.
03-29-2004 17:02:28
I plow with the same plow, works great once I got it adjusted to the eagle hitch, I do have front wheel weights, however I don't think you should have any problem with a two bottom,,,,, gl Bernsy
C. Amick
03-29-2004 13:38:08
I bolted a piece of rectangular tubing and a thick metal plate across the front of mine using the bolt holes in front of and just below the grill. It works as a counter weight and as a bumper. Had to keep it low enough so that the grill can be opened. You will need some long bolts.
