Tire Size
Randy
03-28-2004 17:53:58
I have a Case D that has 13.6x26 rear tires on it and I have found an excellent set of almost new that are 16.9x26. Can anyone tell me if these will fit my rims and tractor? What is the difference? Is it height, width, or what? Any advise at all would be appreciated.
Jim M
03-29-2004 16:50:03
 Re: Tire Size in reply to Randy, 03-28-2004 17:53:58
They put 16.9 x 26 tires on DOs alot in Florida. Some also used 18.4 x 26 tires also. You need 15" rims for the 16.9 tires. I have a pair of diamond 18.4 tires on 20" rims.
dctom
03-29-2004 12:16:53
MAY BE OK BUT YOU CANT USE THE PULLY THAN WITH OUT THE SPACEER IN THE AXLE, JUST DONT INFLATE THEM TOO MUCH AND SHOULD GIVE YOU BIG FOOT PRINT
Glenn FitzGerald
03-28-2004 20:49:39
Significantly taller and 3.3" wider. I would not go any wider than a 15.5 on a 12" rim. Your rim may be 11". However they will fit on. The tire will be crowned and will not wear uniformly. Those D's do need more tire, I agree! Glenn F.
